neilturbo Posted March 10, 2011 Posted March 10, 2011 right going get car fueling checked and c9 set to a bar heres my modshdi fmic j perfomance full exhaustreconditioned ct9hks actuatoravcrjam fccd2 fpr std ported manizisco screamer pipe air filter relocated braided turbo oil feed question is 2 mappers said they want me get bigger injectors and a neo will car be ok with out them as?? i know plenty cars running 1 bar with fcd and boost controllers Quote
starlet666 Posted March 10, 2011 Posted March 10, 2011 with your fuel pressure regulator u defs dont need injectors, i have been running between 20 and 26psi on 315cc injectors, and before they were in i had the stock ones, just with high rail pressure....stock injectors are fine up to about 180hp at the wheels before u start running in2 troubles, and most ct9's wont get those numbers real easy Quote
