Hi,
My car has been sitting around for about 3 weeks outside at my work car park.
The rear lights have alot of condenstion in them.
Whats the cure to sort out the problem.
Thanks
Shahzad
Best way would probably be to split them and let them dry. My 98 Glanza units are only held together by screws and a rubber seal, so open it up and check there isn't a hole or split anywhere :)
While they're split, spray the insides silver/chrome :)
Looks a lot better tan the greyish plastic look!
Do you have to use a special paint for that?
If some bathroom seal is fine i will use that.
