Jap Mini Posted March 29, 2011 Posted March 29, 2011 Hi GuysI'm brand new to the forum, I'm from Durban, South Africa, I have a 4EFTE motor in my mini. I need some help connecting the vacuum pipes correctly.I don't have a solenoid for low and high boost but I do have a boost tap.I currently have the actuator with two pipes on one side of the diaphragm, one vacuum pipe comes out the turbohousing into the one pipe of the actuator, the other pipe of the actuator goes into the tap. One output from the tapis vented to atmosphere and the other output is connected to my boost guage.My dump valve(BOV) is connected to my intake vacuum.This is a pic of the actuator. My actuator is not opening the wastegate!! What is the problem? Quote
Stulet-GTT Posted March 29, 2011 Posted March 29, 2011 Sounds like actuator is knackered or needs adjusting... Quote
