jham Posted March 29, 2011 Posted March 29, 2011 Just fitting my EBC nearly there now, just a quick question.i have to run a vacuum hose via a t piece from inlet system to EBC.now i already have a 3 piece split on this for my boost gauge is it ok to put another one in there like the pic below? Quote
neilsmith Posted March 29, 2011 Posted March 29, 2011 I would say its fine mate as long as you make sure the vacumme hoses are tight and there arent any leaks. Quote
jham Posted March 29, 2011 Author Posted March 29, 2011 ok all fitted now think its ok, set to just below 1 bar at the moment till i can have another play.Seems to pull fine and turbo spools as it should just not sure if ive done it right though,when i come on boost i get a fast clicking sound coming from somewhere and im not entirely sure my boost gause is reading what my EBC states its boosting to. could this be because of the way ive put them on same vacuum hose? is there any other way of doing it?any info pleaseok all fitted now think its ok, set to just below 1 bar at the moment till i can have another play.Seems to pull fine and turbo spools as it should just not sure if ive done it right though,when i come on boost i get a fast clicking sound coming from somewhere and im not entirely sure my boost gause is reading what my EBC states its boosting to. could this be because of the way ive put them on same vacuum hose? is there any other way of doing it?any info please Quote
jham Posted March 29, 2011 Author Posted March 29, 2011 have just read the clicking sound could be the solonoid hiding boost, so could possibly have the vacumm hoses the wrong way round on the valve unit maybe.. cant think what else could cause the problem Quote
yaristurbo Posted March 29, 2011 Posted March 29, 2011 sticking injector(not a problem), but most prob solenoid mines was really annoying, try putting a small piece of rubber between it and the chassis, stops the sound from transfering as much Quote
jham Posted March 29, 2011 Author Posted March 29, 2011 definatly solenoid after bit more investigation, so itsw just a case of trying to make it quite then its not restricting me in anyway then? Quote
