kdowg Posted April 4, 2011 Share Posted April 4, 2011 orite there im changing a engine over on me glanza tomorra and never done it on a glanza before and I've heard the shafts can be tricky to get out the gearbox just won dering if there are any tips to get them out I've never looked at the shafts or anything so new to working on glanzas any help will be greatly appreciatedcheers dan Quote Link to post Share on other sites
whiteglanzav Posted April 4, 2011 Share Posted April 4, 2011 undo the bottom ball joint - 2 bolts and a nut at each side, then seperate where they sit.then knock the shafts out of the box with something, using the lip on the green bulky part of the shaft - get someone to pull the wheels away from the car while you manoeuvre the shafts out - easy as that you don't even need another person just makes it easier Quote Link to post Share on other sites
kdowg Posted April 4, 2011 Author Share Posted April 4, 2011 undo the bottom ball joint - 2 bolts and a nut at each side, then seperate where they sit.then knock the shafts out of the box with something, using the lip on the green bulky part of the shaft - get someone to pull the wheels away from the car while you manoeuvre the shafts out - easy as that you don't even need another person just makes it easierahh sound man this mean yah dont need to take the wheels off or owt thort i read ages ago about clips holding the shaft into the box :S cheers for yah help matey just hoping all goes to plan off topic but is there anything else i need to look out for or tips when removing the engine? cheersdan Quote Link to post Share on other sites
rob_bower Posted April 4, 2011 Share Posted April 4, 2011 Don't forget to drain the box oil! Otherwise it could get messy! Lol Quote Link to post Share on other sites
