chrislucas121 Posted April 5, 2011 Posted April 5, 2011 Hi where do you put the oil in the gear box and how much? Its on a 1995 gt Turbo import Quote
nazzurro19 Posted April 5, 2011 Posted April 5, 2011 do a search and find a guide you will need a 25mm socket to undo a couple theres one on the bottom to drain it one on top just behind the battery tray (to fill) and Nother half way down gearbox which is the indicator youll need 2.5l of gearbox oil then depending on if u got a lsd diff etc Quote
GTnomez Posted April 5, 2011 Posted April 5, 2011 ^ What he said.Drain out the oil using the bottom nut, tighten that back up then loosen the middle nut just by the gearbox mount and fill up using the top hole.When it seeps out from the loosened middle hole then its enough. Quote
Stulet-GTT Posted April 5, 2011 Posted April 5, 2011 http://www.toyotagtturbo.com/forums/showth...rbox-Oil-Change Quote
