my drivers door has is changing from blue to white from sun exposure :)
is there any product i could put on to revive it?
if i polish it up it last for couple of hours then goes back to how it was.
its like wen a red car goes pink
apart from a good polish/ and wax there isnt much you can do to my knowlege!! some company like autu glym do paint restorers might be worth a try!
reds fade for a complelty different reason its due to what is used to colour the paint all reds use an oxide which continue to oxidise over time!!
Rob
without seeing it, sounds like you have a problem with the lacquer on the door. probably had a spray job in the past.
only way to really cure this if it is the problem is to get i rubbed back and blown over again.
yea the red idea was just an example of how it looks,
considered a blow over but would be hard to get colour match on a 16year old car dont you think?
may have to try auto glym or something
