t-j-wilson Glanza V Posted April 20, 2011 Posted April 20, 2011 I bought an adjustable HKS, after i had paid and everything i then realised i forgot to ask if it was the 'hole type' for the GT or, Cir-clip for my ep91.. When it arrived it was for the ct9a, Is it OK to connect the actuator arm to the wastegate using a nut and bolt, does there have to be free movenent or can i do them up tight? Im not sure whether it rotates on the pin and c-clip part(standard actuator)? Is this actually OK to do this?Help would be great Thanks, TobieP,S , seller was great and offered a full refund if not, but i want to get this one working, Quote
Driver Posted April 20, 2011 Posted April 20, 2011 A nut and bolt is fine, dont do it too tight though as its a pivot point for the actuator, use a locknut and leave it so it can move freely but not loose Quote
t-j-wilson Glanza V Posted April 20, 2011 Author Posted April 20, 2011 Thanks alot for replying, i'll crack on with that Tobie Quote
