GT_Neil Posted February 18, 2007 Posted February 18, 2007 my boost seems to hesitate then come on full ?? for example in 3rd gear doing say 50 right off the accelerator ready to boost, i then boot it, it boosts, stops, then boosts and continues until i stop accelerating. that all happens in the space of a second but is clearly noticeable and always happens now in all gears except first. Not sure about second gear though. Quote
paul w Posted February 19, 2007 Posted February 19, 2007 Check your leads/plugs and dizzy mate. Quote
GT_Neil Posted February 19, 2007 Author Posted February 19, 2007 Check your leads/plugs and dizzy mate.ok will do, erm i know this sounds dim. But what is the dizzy? ... Distribution? Quote
GT_Neil Posted March 31, 2007 Author Posted March 31, 2007 im certain this is not boost related now, its got worse now and im 99% sure its the clutch causing the hesitation. when accelerating hard in mainly the higher gears revs will fly and then drop. Its started to smell of burnt clutch when this happens badly now. Quote
woodchopper87 Posted March 31, 2007 Posted March 31, 2007 yes thats exactly what happen to mines i thought it was boost but it was the clutch it only happened in 3rd though floor it turbo kicks in revs flys up then comes back down so i got an uprated clutch what a difference it makes it bites everytime you change gear and no more clutch sliphope this helped you abit Quote
GT_Neil Posted April 1, 2007 Author Posted April 1, 2007 yes thats exactly what happen to mines i thought it was boost but it was the clutch it only happened in 3rd though floor it turbo kicks in revs flys up then comes back down so i got an uprated clutch what a difference it makes it bites everytime you change gear and no more clutch sliphope this helped you abitthanks for info mate, thats exactly what happens with mine, but it dose it in 4th aswell, somtimes even secound. Quote
