YoungStig Posted April 27, 2011 Share Posted April 27, 2011 ok Swap my engine over on sunday from the red glanza into an 82.i had to change starter moter, breather on inlet mani and a few sensors on thermo housing.of changed the oil fuel filters.Set timing up now spot on in safe mode.found that the 3rd lead aint sparking so pulled it out and its sparking (arching when its about 1cm away but plug it back in and its not changed the dizzy cap still same any help will be rewarded at J.A.E with a pint thanks Quote Link to post Share on other sites
YoungStig Posted April 28, 2011 Author Share Posted April 28, 2011 ok swaped spark plugs and injectors.some who when i pull nu3 plug lead out it works when it ark's on the pug runs fine Quote Link to post Share on other sites
Idrees Posted April 28, 2011 Share Posted April 28, 2011 Have you tried a different set of HT leads? Quote Link to post Share on other sites
YoungStig Posted April 28, 2011 Author Share Posted April 28, 2011 yes mate put jonnys on off his s yesterday junt the 3rd 1 likethey brand new ngks Quote Link to post Share on other sites
rorenapier Posted April 28, 2011 Share Posted April 28, 2011 Leads on the correct way?How did you manage to set the timing with it running badly?Sounds ignition related Quote Link to post Share on other sites
YoungStig Posted April 28, 2011 Author Share Posted April 28, 2011 it was a craked plug sored now will it be ok to run on 3 bkr7 eix and1 6 till i get 1 tomoz Quote Link to post Share on other sites
rorenapier Posted April 28, 2011 Share Posted April 28, 2011 I wouldnt run it personally BUT its up to you weather you want to or not.Can you not get a set of plugs today? Quote Link to post Share on other sites
YoungStig Posted April 28, 2011 Author Share Posted April 28, 2011 ok orded plugs now get it at 5ish whooo Quote Link to post Share on other sites
Pinkygti Posted April 30, 2011 Share Posted April 30, 2011 If it sparks when you take it out but seems that it doesn't when you put it in, then problem areas are:Plugs,Leads,Injector,Wiring,Can you smell fuel when cranking/running?PinkyB) Quote Link to post Share on other sites
Pinkygti Posted April 30, 2011 Share Posted April 30, 2011 My bad, computer didn't update lol, glad you found the problem quickly, but yea I wouldn't drive it or you might get bore washPinky Quote Link to post Share on other sites
