xx YICK xx Posted April 27, 2011 Posted April 27, 2011 Right lads, Got some 98 spec rear lens covers from toyota today, I know the screw holes dont line up so do i get a 98 spec uk cluster or do i have to modify the lens cover, Thanks Quote
starlet786 Posted April 27, 2011 Posted April 27, 2011 yep you will just have to drill little holes in your lights and job done make sure there bang on correct other wise water will get into them Quote
xx YICK xx Posted April 28, 2011 Author Posted April 28, 2011 yep you will just have to drill little holes in your lights and job done make sure there bang on correct other wise water will get into themThanks alot matey Quote
eliasglanza Posted December 7, 2020 Posted December 7, 2020 is it possible to find out the part numbers of both sides lenses? Quote
RoyalDutchie Posted December 7, 2020 Posted December 7, 2020 (edited) 1 hour ago, eliasglanza said: is it possible to find out the part numbers of both sides lenses? Do you mean the red bulb covers or the the 98 spec rear lenses? facelift lenses: LH lens - 81561-10340 RH lens - 81551-10360 Both will most likely be discontinued. Edited December 7, 2020 by RoyalDutchie Quote
eliasglanza Posted December 7, 2020 Posted December 7, 2020 3 minutes ago, RoyalDutchie said: Do you mean the red bulb covers or the the 98 spec rear lenses? LH lens - 81561-10340 RH lens - 81551-10360 Both will most likely be discontinued. Ι ΜΕΑΝ ΤΗΕ LATEST LENSES FROM THE FACELIFT (THE GREY LENSES) Quote
eliasglanza Posted December 7, 2020 Posted December 7, 2020 ACTUALLY, I'M LOOKING FOR 2 TYPES OF LENSES THE SECOND TYPE IS THIS... Quote
RoyalDutchie Posted December 7, 2020 Posted December 7, 2020 3 minutes ago, eliasglanza said: Ι ΜΕΑΝ ΤΗΕ LATEST LENSES FROM THE FACELIFT (THE GREY LENSES) facelift lenses: LH lens - 81561-10340 RH lens - 81551-10360 1 minute ago, eliasglanza said: ACTUALLY, I'M LOOKING FOR 2 TYPES OF LENSES THE SECOND TYPE IS THIS... RH lens: 81551-10370 LH lens: 81561-10350 Quote
eliasglanza Posted December 7, 2020 Posted December 7, 2020 You're great mate. thanks a lot for your help Quote
