_shaun_ Posted April 30, 2011 Posted April 30, 2011 was playing around with ebc and when i put foot down hitting like 1.1bar the engine management light came on so drove home turned car off (thinking code would be stored) went to get bit of wire and done test and no error codes came up arent they ment to stay stored in ecu even after ignition been turned off?am running a td04 and a emu cheers shaun Quote
_shaun_ Posted April 30, 2011 Author Posted April 30, 2011 when maping we got a speed signal code once or twice due to how it had been maped. which is a code 42 and it says codes 16,42,43,52 all get erased when igition is switched off so guess that must be it Quote
