I'm looking into getting some GT4 twin pots, after a bit of reading around, a good disc to use is a 255mm diameter, 25mm wide Prius disk.
Stock discs are 17mm vs 25mm Prius and a 3mm disc spacer is needed on each side, is that correct?
Meaning there would be an additional 10mm spacing out?
Would I need longer wheel studs?
Thanks
Amjad
Guest Enzo
short anser yes,
lucida, 4 runner etc would do i cant remember the size off the top of my head though
I have some prius discs mate if your interested they are drilled and grooved brand new. They require 6mm spacer and longer wheel studs.
Thanks for the reply guys!
Lee how much are you after for them? Any idea of where I can get wheel studs that deffo fit?
And the spacers, is it 6mm either side not 3mm?
I was after £60 for discs and £50 for calipers. 6mm each side yes as with these 3mm isnt enough to give the disc clearance, i do have 2 3mm spacers i could throw in which cost £20 but you would just need a 6mm spacer making then.
