annoying problem.
when I'm driving along it will cut all power and boost...
does it when I'm on the motorway mainly but sometimes its fine.
Doesn't matter if I'm on or off it boost it still does it... engine management light comes on then goes 3seconds later.
its not boost cut... and would it have anything to do with my rev gauge not working sometimes?
anyone have any ideas?
how would I check that?
It sometimes happens when I go over bumps hard.
Cuts all revs and boost but keeps the engine running.
im sure if your engine light came on you could do a diagnostic check through the engine bay port and find out if its a sensor issue, even if the light doesnt stay on it mite still tell you
just search on here for the method on bridge the to pins in the diagnostic port
done the diagnostic check and it comes back with error 24. ATS air temperature sensor.
