DaAvid 49 Posted May 11, 2011 Posted May 11, 2011 I need some advice my son has a Starlet SR s reg 1.3 we sent the reg to camskill and the supplied via blueprint new HT leads to replace the old ones at the same time we replace the rocker gasket that was laeking and sprayed the rocker cover matt black as per the guide of the forum (thanks for that) all went well apart from the fcat the ends of the new leads from Blueprint were not splayed in at the ends and they do not fit 100% causing a misfireBlueprint via camskill have said we must have changed the distributor to an aftermarket this we have not doneCan anyone suggest some leads that may fit the car is a 1999 EP91 Starlet SRThanks Quote
james@cjperformance Posted May 11, 2011 Posted May 11, 2011 do the ones you have on there at the moment have just a rubber boot or is there a plastic clip?there are two different types of ht leads for them. Quote
DaAvid 49 Posted May 11, 2011 Author Posted May 11, 2011 The old ones have a clip underneath I have looked through the paperwork with the car and the HT leads were replaced at some point in the past, I have a picture but cant seem to attach Quote
