liamg40 Posted May 23, 2011 Posted May 23, 2011 hello,i`m very new to glanza`s and this site,i wanted to keep my glanza fairly standard untill today when i found 2 td04 turbo`s just sitting around in my work shop,these are off a mitsubishi shogun i think and i would really like to put one on my glanza if I've`e got the right turbo`s that is ;) , ive been searching and reading up on threads on this site for a few days and have found some good info, but club g40 is a lot smaller than this site and have got cofused a few times. Quote
N80Jamie Posted May 23, 2011 Posted May 23, 2011 Basics, you'll need:-td04 turbo-td04 suited manifold-td04 suited decat-oil lines-fmic-Walbro fuel pump-adjustable actuator-Possibly a slim radiatorEither-fuel cut defender-rising rate fuel pressure regulator Or-ecu (such as an Emanage blue or ultimate + map)Give it a search. This has been covered 100000000000000 times ;) Quote
Fro Posted May 23, 2011 Posted May 23, 2011 if they are from a shogun are they not diesel turbo's? Does that matter? Quote
liamg40 Posted May 26, 2011 Author Posted May 26, 2011 i`m not sure, can anyone confirm if they are ok to use from a shogun?if they are from a shogun are they not diesel turbo's? Does that matter? Quote
nazzurro19 Posted May 26, 2011 Posted May 26, 2011 most people use scoobys ones but im pretty sure you cant use petrol to power a diesel turboor its the other way round u cant use diesel to power a petrol turbo sutin along them linesanyway td04 is a cheap turbo pick em up around the £50-£100 Quote
GTnomez Posted May 26, 2011 Posted May 26, 2011 Im sure that the mitsu spin opposite to the sccoby.But anyway, some td04 have square inlet like from a volvo.So firstly you want a triangle style inlet from the turbo and then you will know it can match most manifolds on here Quote
liamg40 Posted May 27, 2011 Author Posted May 27, 2011 yeah they are both triangle inlets.Im sure that the mitsu spin opposite to the sccoby.But anyway, some td04 have square inlet like from a volvo.So firstly you want a triangle style inlet from the turbo and then you will know it can match most manifolds on here Quote
