Armand Posted June 1, 2011 Posted June 1, 2011 recently got new head on starlet after a year lol..al piped up running ok.when i rev her above 2k engine light comes on! havent took her for test drive or anything yet.just wondering has anyone came across this? Quote
chris H Posted June 1, 2011 Posted June 1, 2011 Do a diagnostic mate, bridge terminals T1 and te1 in the diagnostic port under the bonnet and switch the ignition on but don't start itcount haw many times the engine light flashes, short pause then count the next.eg **** ** is code 42 Quote
Armand Posted June 1, 2011 Author Posted June 1, 2011 Do a diagnostic mate, bridge terminals T1 and te1 in the diagnostic port under the bonnet and switch the ignition on but don't start itcount haw many times the engine light flashes, short pause then count the next.eg **** ** is code 42just bridge with bitta wire? and does it flash straight away ? Quote
chris H Posted June 1, 2011 Posted June 1, 2011 Yeah a paper clip is perfect mate,It won't start flashing till you switch the igmition to the on position.There's a chart somewhere on here that has the error codes on and what they mean Quote
Armand Posted June 1, 2011 Author Posted June 1, 2011 Yeah a paper clip is perfect mate,It won't start flashing till you switch the igmition to the on position.There's a chart somewhere on here that has the error codes on and what they meancode 52 - knock sensor.. wers it? lol Quote
chris H Posted June 1, 2011 Posted June 1, 2011 On the back of the block, just below your water pump pipe Quote
Armand Posted June 1, 2011 Author Posted June 1, 2011 On the back of the block, just below your water pump pipeCheers dude. I'll get her on the lift tomoz an av a look. Just strange The light only comes on wen I rev her :-/ Quote
chris H Posted June 1, 2011 Posted June 1, 2011 Did you check your timing?Could just be that the connector has come loose. or a faulty sensor Quote
Armand Posted June 1, 2011 Author Posted June 1, 2011 Did you check your timing?Could just be that the connector has come loose. or a faulty sensorYh timing seems good. She's running to well for it to be off. Hope it's a wire loose :-/ Quote
