jason_l Posted June 6, 2011 Posted June 6, 2011 Hi Everyone,Right need a bit of help with this, not sure if anyone will know. I have a standard LSD gearbox fitted on the Demon and im currently measuring up for the custom drivshafts to be made, however have come across a bit of a problem. The driveshafts i have are from a standard non LSD starbo and they don't actually fit into the cup part on the gearbox as they are too fat. Are the only other drivehsafts that fit into the cups the lsd box ones? Obviously the length isn't a problem as they are getting custom made, the important part is the fitting that goes into the cups is correct? Im guessing that i can't change the cups for a non lsd box type??? This was a complete kick in the face as im literally just about to get the shafts made up Jason Quote
Taggy Posted June 6, 2011 Posted June 6, 2011 HeyI know the two driveshafts are not interchangable, but like you said length isnt an issue so you could just change the cup part ito the gearbox, i am not 100% on it, i guess if you count the splines and they are the same you could buy your self a stock set and put in to fit your standard shaftsTake em out and count the splines on them and compare the stock ones, think they are listed on www.camskill.comHi Everyone,Right need a bit of help with this, not sure if anyone will know. I have a standard LSD gearbox fitted on the Demon and im currently measuring up for the custom drivshafts to be made, however have come across a bit of a problem. The driveshafts i have are from a standard non LSD starbo and they don't actually fit into the cup part on the gearbox as they are too fat. Are the only other drivehsafts that fit into the cups the lsd box ones? Obviously the length isn't a problem as they are getting custom made, the important part is the fitting that goes into the cups is correct? Im guessing that i can't change the cups for a non lsd box type??? This was a complete kick in the face as im literally just about to get the shafts made up Jason Quote
