just bought a forge piston and rods
just bought these and i dont no wot ells i need any help would be grate
Wiseco 75 mm dished pistons (4 ea), piston rings (4 sets), wrist pins (4 ea) and locks (8 ea)
Scat connecting rods (4 ea) with ARP 3/8" rod bolts
thanks
thanks
depends on what you gonna do.
If it s just a rebuild:
Toyota/OEM Full Engine Overhaul kit
Water Pump
Oil Pump
Toyota/ACL Bearing Set (Mains, Conrods and Thrust Washers)
ARP Headbolt set
Ugraded/Performance Clutch
Not sure if i missed anything but if you gonna do a rebuild i think this list covers the stuff that you should get.
