Have just fitted a famed kit on the group buys and it helps through the gears but it struggles to start now I have to give it some gas to start it I didn't before, if I don't it will turn over then stop any help please??
Check that you haven't knocked anything on install. I don't think installing a damper kit would cause this as other than bolts it has no other connection to the car.
Knocked an earthing wire??
There is an earth on the engine mount so perhaps check that you replaced it when fitting the engine mount bracket.
