ep91_glanza Posted June 9, 2011 Share Posted June 9, 2011 i recently had a loud knocking noise coming from my engine so i took the engine out and basically took it all apart and found out that i span one of my conrod bearings and it totally worn the bearing down and has worn the little lip/groove on the crank shaft where the conrod bearing sits and there is signs of wear on the conrod,im just wondering if i just replace the bearings or what i need some advice cheers.if pics would be easier i can get them up tmrw Quote Link to post Share on other sites
mrkd5916 Posted June 9, 2011 Share Posted June 9, 2011 by the sounds of it you will need the crank reground, best to take it to a machine shop, see what they say, Quote Link to post Share on other sites
ep91_glanza Posted June 10, 2011 Author Share Posted June 10, 2011 Ive done a bearing does that mean that ive got to get a different size bearing or what?? Help much appriciatado!!! Lol Quote Link to post Share on other sites
