Misterdan88 Posted June 14, 2011 Posted June 14, 2011 quick question i just need to know for sure, will EP82 front discs fit a 97 glanza?Also would front braided lines from EP82 fit a V too? did tried to search but got bored of it taking so long.. lolthanks alot! Quote
mech5107 Posted June 14, 2011 Posted June 14, 2011 Disks are the same (GT/Glanza/Paseo)Calipers are the same.Lines are the same. Quote
Misterdan88 Posted June 14, 2011 Author Posted June 14, 2011 you are the man. just wanted to make sure! Quote
shorty Posted June 14, 2011 Posted June 14, 2011 discs are NOT the same, early mk1 gt has a 54mm centre bore on the disc and the later gt and glanza model has a 55mm center bore! just make sure they are not mk1 gt discs, having a larger centre bore than you need isnt an issue but aving one thats too small is as it wont go over the hub so the alloy wont sit right Quote
Misterdan88 Posted June 14, 2011 Author Posted June 14, 2011 after all that i got out bid any way lol cheers any way guys! Quote
