fattony Posted June 18, 2011 Posted June 18, 2011 just wondered if anyone has removed the rear side windows on their starlet, are they glue in or push fit?do i need to get the old cheese wire out?? lolcheers! Quote
LeeG Posted June 18, 2011 Posted June 18, 2011 this for glanza? if so ive done it with long stanley blades from the inside take time but ul get it as the bonded on Quote
Idrees Posted June 18, 2011 Posted June 18, 2011 As above, EP91 windows are bonded on so they would require cutting out. Quote
Rob Scott Posted June 18, 2011 Posted June 18, 2011 yeah they need cutting out, go to your local car window suppliers and ask for some cutting wire. you need to take the plastic trim off the windows, poke a small screwdriver through the glue and slide the wire through. get a mate to help you. one each side of the window and saw through the glue with the wire Quote
fattony Posted June 20, 2011 Author Posted June 20, 2011 yeah its for my ep91, repainting when i return from my hols in july, just trying to chose between three colours, all green, none standard! loli take it front and rear windows are both stick in's to then?!lots of prep work to do, last owner was a little more than careless when it came to cleaning the car and not denting her!! Quote
