N80Jamie Posted June 19, 2011 Posted June 19, 2011 Today I took one of the springs out of the wastegate and I'm now peaking at 0.74bar. Until I get an ecu sorted I'm only running a RRFPR at 2.4bar pressure. Is this fueling for the td04 for the timeBeing? Quote
ep_brad Posted June 19, 2011 Posted June 19, 2011 i wouldnt be boosting it until the fueling has been checked. its not worth the risk. Quote
GAZ@A&G_TUNING Posted June 19, 2011 Posted June 19, 2011 why or who se the fuel pressur to 2.4bar? Quote
N80Jamie Posted June 19, 2011 Author Posted June 19, 2011 It was set at this when I bought the car. It was running a hybrid ct9 at about 0.7-0.8bar. I'm sure either 2.2 or 2.4 is standard fuel pressure right? I'll just not boost until I get an ecu sorted if it's not safe. Quote
james@cjperformance Posted June 19, 2011 Posted June 19, 2011 Just get the fuelling checked and run the car like that until you sort an ecu for it:) Quote
