wssoR Posted June 21, 2011 Posted June 21, 2011 As above, and would you be able to help me?CheersRoss Quote
LeeroyV Posted June 21, 2011 Posted June 21, 2011 As above, and would you be able to help me?CheersRosshey buddy...just got myself a emb and have yet to wire it up but i spoke to a few companies about getting it mapped and dynotech dartford were wanting £450 for the pleasure so in the end i spoke to tuning developments and they maybe a few miles away but to map the emb they want £210 and then £75 to fit the emb which i thought was good. Im planning on taking a road trip up to see them soon ;) Quote
wssoR Posted June 21, 2011 Author Posted June 21, 2011 Sounds good, if I haven't found someone to help by then then I'll probably join you. Quote
LeeroyV Posted June 21, 2011 Posted June 21, 2011 let me know if you find someone that can wire them up as im join in but otherwise could be a fun run up to tuning developments if ya fancied it Quote
wssoR Posted June 21, 2011 Author Posted June 21, 2011 Well I'll definately be needing it mapped so either way I'm gonna go up there, may go race-tech though a's I've heard good things about them Quote
LeeroyV Posted June 21, 2011 Posted June 21, 2011 yeh ive heard very good reports about race tech but tuning delevopments also come highly rated on tgtt plus with fitting the emb it seemed like a good deal but if someone local can help out fitting the emb then Quote
Starbuck Posted June 21, 2011 Posted June 21, 2011 I fitted my own in about 1 hour. If u can follow a diagram and can solder a bit its worth the saving of 75notes. Although if u install it yourself on a second hand unit then you can't boost until mapped. Id offer my services as I'm 30mins off the M6.... but it'll add to your journey.However td did my tuning...... great guys! Quote
ep_brad Posted June 21, 2011 Posted June 21, 2011 im using these guides to wire mine in. Ive also ordered a field harness to make it even easier to wire inhttp://www.austarletclub.com/forums/index....showtopic=13602 Quote
