jdm-andy Posted June 27, 2011 Posted June 27, 2011 how much does a std ct9 boost too? i put my boost gauge in today as i want to put a manual boost controller on. I am getting 8-9psi on high and 4-5 on low. ( i saw 8-9 because the gauge wasnt on 0 when i installed it as i only had 20 mins to fit it all lol. so i will be doing it again. Quote
ro55ifumi Posted June 27, 2011 Posted June 27, 2011 Depends on set up, but with right mods 1 bar , 14.5/15psi John Quote
jdm-andy Posted June 27, 2011 Author Posted June 27, 2011 Depends on set up, but with right mods 1 bar , 14.5/15psi John1 bar id need a fcd for that, and im unsure about it Quote
ro55ifumi Posted June 27, 2011 Posted June 27, 2011 1 bar id need a fcd for that, and im unsure about itFMIC,De Cat,Mani,Exhaust air filter reloaction some form of management, plug an play ecu or e-mange.Or all of the above except management and use a fcd, fpr etc but safest way is management!!You will get fuel cut without any of the above an possible boost creep!!John Quote
jdm-andy Posted June 27, 2011 Author Posted June 27, 2011 FMIC,De Cat,Mani,Exhaust air filter reloaction some form of management, plug an play ecu or e-mange.Or all of the above except management and use a fcd, fpr etc but safest way is management!!You will get fuel cut without any of the above an possible boost creep!!Johni have a front mount, want steve gts full stainless, getting a relocation or making one, hmmm manifold and de cat next Quote
ro55ifumi Posted June 27, 2011 Posted June 27, 2011 Dont up boost on standard mani you will fry the 3rd cylinder as its restricted, plenty of info on here do a searchJohn Quote
