Reverse scoop only useable with a front mount intercooler. When fitted it acts as a vent to draw hot air from under the bonnet.
what car you got? glanza V glanzas or repped glanza?
Replica with a reverse scoop
Ooh nice well Ill have to doing a turbo conversion and put a fmic on then to make it work :)
Am I also right to say that the scoop will cause drag?
And the reverse scoop would benefit if the wind is blowing your way?
Bonnet scoop is there to run cold air onto your top mount, but if you
have a front mount intercooler then ther is no use for the scoop as the
air is been forced straight to the fmic threw the bumper and thats
why people use reverse scoops to stop the rain water or water from car wash
gettin in on top of the engine an causing all kinds of problems :)
Diller
