Just looking at the instructions for my gauges..
Red - 12v
Black - Earth
White - Ignition 12v
Orange - Dash illumination
I want the gauges to be lit up all the time on ignition regardless of whether sidelights are switched on. Do I still have to connect up the orange? If so, where to?
Also, can I connect all 3 gauges to the same wires for 12V, earth etc..?
Thanks
Amjad
Do you have to wire them all seperately or are they daisy chained?
If you leave the orange wire off it will just constantly be bright and wont dim when the headlights are turned on so thats not a problem.
Not sure what daisy chain is?
They all have their own 4 separate electrical wires..?
Cool, same as the boost gauge then, will the colour switch still work without orange wire?
So the gauges dont plug into each other and then a controller?
Pretty sure it would be fine to wire them all into the same place mate.
And I dont think the orange wire would affect that, just try it and see :)
Nah there's two plugs in the back, one for this set of wires and another for a harness, which is optional
Cool, thanks for the help I'll give it a shot now if I can find my spare wiring :)
