steady_eddy Posted July 3, 2011 Posted July 3, 2011 started my glanza up this morning and it took ages to get going and noticed straight away it was misfiring.so changed the distributor cap, ht leads, and spark plugs... but still no spark on cylinder one.... but when i rev it up above 3k it starts to make a tapping sound like metal on metal......? no smoke and just had the headgasket done about 2 weeks ago. engine mods: zisco mani, zisco decat, tail wastegate, fmic, relocated air filter and running 0.6bar of boost. any suggestions? Quote
jackjohno Posted July 3, 2011 Posted July 3, 2011 started my glanza up this morning and it took ages to get going and noticed straight away it was misfiring.so changed the distributor cap, ht leads, and spark plugs... but still no spark on cylinder one.... but when i rev it up above 3k it starts to make a tapping sound like metal on metal......? no smoke and just had the headgasket done about 2 weeks ago. engine mods: zisco mani, zisco decat, tail wastegate, fmic, relocated air filter and running 0.6bar of boost. any suggestions? Have u done a compresion test?? Quote
steady_eddy Posted July 4, 2011 Author Posted July 4, 2011 Done a compression test today results:done a compression test today resultscylinder 1= 20 psicylinder 2= 20 psicylinder 3= 140 psicylinder 4= 140 psiengine was warmed up, throttle fully open and put some oil in 1 and 2 but still no change... my dads mate said valve springs broken or broke valve.any ideas? Quote
nastyrash 2003 Posted July 4, 2011 Posted July 4, 2011 head gasket blown bettween 1&2 it sounds like. chris. do a leak off test with plugs out and you will here it blow across and out the other. Quote
steady_eddy Posted July 4, 2011 Author Posted July 4, 2011 head gasket blown bettween 1&2 it sounds like. chris. do a leak off test with plugs out and you will here it blow across and out the other.how do i do a leak off test? Quote
nastyrash 2003 Posted July 5, 2011 Posted July 5, 2011 go on sealy tools and ulook under cylinder leakage tester. thy about 30 quid.u need a compressor to operate it thw Quote
