i have leak somewhere, i have replaced some pipes with silicone ones, but have a leak somewere. Anyone have a vacum diagram as i found a random hose on the subframe and have no idea were its from.
I see you do'nt have any aircon so you might have a few lying around from that and lots of wires unplugged.
Does your car idle go up and down much?
it drops at idle to about 600rpm sometimes. Although i just changed the pipe from the breather to inlet manifold earlier as i think it was kinked, maybe that will sort it.
