Remove the blanking plugs from the 2 top ports, and plug the other 2 bottom ports, and try that.
As above. This is your problem. What you've done is effectively fitted a HUGE bleed valve, you'd just make infinite boost.
That's what I did last night Rory and is sorted, I knew those bottom 2 shouldn't have been open :p lesson learnt! Cheers guys!
