when we did my mates scooby we started to take off all the ancilaries etc
id start with all the fuel lines, pipes etc and connectors , get lots of pics and use masking tape to label connections
will make it easier putin it all back
Thanks bud i have already removed all wires connections Etc. I have been told its a easy job just i don't wanna fuck anything up :/
what did you do before painting it? Or did you leave it in there? I allways thought you took every single thing off the car
remove rad, undo the bottom ball joint at each side (2bolts+1nut) to allow driveshafts out of hubs then remove them from gearbox, disconnect exhaust at bottom of cat and undo rubbers on centre section on exhaust tht'll allow enough room to get engine out, then remove bolt from rear gearbox mount then its just matter of either using crane to lift out or trolly jack under engine and strap round engine and lower it down and remove from underneith. (thats the way ive done it many times.)
i Didn't repaint the engine bay 1 thing i left :(
