right looking at coilovers ect? how much lower are the strut tops on the ep*5 compared to the standard ep's and also is the standard ep's coilover spring rate ok or do the 4wd's need a stiffer rear spring rate??
i need to know asap!! got somthing planned :o
standard springrates are fine i rocked about on a set of bc coils at their lowest setting for two months
id say its 2-3 inches sorter.
what you got planned
5kg/mm on the bcs but would be good to make them softer at 4kg/mm
are you speaking to Gaz shocks/coils
