gt-nick Posted July 31, 2011 Posted July 31, 2011 hey guys just put a new head and gasket and cambelt /rad on and it ran fine so let the coolant go circulate and the fan kick in twice was all good. then it went into a lumpy idle and cut out now there water goin from the inlet into the engine any ideas on wts happend/wt i could of done wrong e.g the hose on the bk of the inlet or sumin ?cheers nick Quote
GT Phayer Posted July 31, 2011 Posted July 31, 2011 you havnt mixed water lines with vacuum lines have you ? Quote
gt-nick Posted July 31, 2011 Author Posted July 31, 2011 you havnt mixed water lines with vacuum lines have you ?um thats wt im thinkin but im sure its sumin to do with the manifold area Quote
GT Phayer Posted July 31, 2011 Posted July 31, 2011 what about the maifold gasket did you replace that ? as theres a water way on the manifold and the gasket blanks it if i remember rightly Quote
gt-nick Posted July 31, 2011 Author Posted July 31, 2011 what about the maifold gasket did you replace that ? as theres a water way on the manifold and the gasket blanks it if i remember rightlyyea replace all gaskets. its like its comin from the top end of the manifold and the comin down into the combustion chambers Quote
GT Phayer Posted July 31, 2011 Posted July 31, 2011 can you take a picture of were its coming in mateyou proberly have put a water line on one of the vacuum inlets Quote
gt-nick Posted July 31, 2011 Author Posted July 31, 2011 can you take a picture of were its coming in mateyou proberly have put a water line on one of the vacuum inletsum i would but ive took the maifold off but the only one i can think ive mixed up is. the one from the thermostat housin and the vacum pipe from the back of the manifold if you no which 2 im on about Quote
GT Phayer Posted July 31, 2011 Posted July 31, 2011 i think ive got some pictures of how its fitted so il did them out and post it up so u can see if you have them wrong Quote
GT Phayer Posted July 31, 2011 Posted July 31, 2011 best thing to do its bolt it back together and try again mate and show pictures how you have connected everything before you start it up Quote
gt-nick Posted July 31, 2011 Author Posted July 31, 2011 best thing to do its bolt it back together and try again mate and show pictures how you have connected everything before you start it upi just been sent a like to a page with pictures and i belive i put the hoses on wrong so im gonna go put it bk together the right time and see wt happends Quote
