as above im wanting to knw whre oil pump is located ??? is it run on
the timing belt ??
i doing a big major service very soon so wanting to know if i should change oil pump or leave it ??
what u guys reckon?
Thanks!
Yes it rotates on the timing belt and can be easily accessed under the bottom cam belt cover. What's the mileage on your engine?
ah thought so :)
erm its around 75k miles atm ????
will be changing all belts, water pump, etc
Thanks!
If you haven't had any problems with oil pressure etc then I'd leave it. I'd only be tempted to change it if it had high mileage.
