t-j-wilson Glanza V Posted August 11, 2011 Posted August 11, 2011 Hey, As the title says really. I get a knocking noise whilst going round roundabouts, and right turns in genera (coming from left side only)l. I've had a loook around and seems like my track rod ends are worn. Would this be causing the problems? What else is there you can suggest for me to check?I also noticed that my disc isn't held on to the hub at all, untill the wheel goes on and locks it. Is this normal, there looks to be a hole for a bolt to go through in the disc, but nothing on the hub itself? Many thanksPs , where would be best/cheapest to buy a set of track rod ends? I want to replace these anyway. Quote
Johnboy GT Posted August 12, 2011 Posted August 12, 2011 Hey, As the title says really. I get a knocking noise whilst going round roundabouts, and right turns in genera (coming from left side only)l. I've had a loook around and seems like my track rod ends are worn. Would this be causing the problems? What else is there you can suggest for me to check?I also noticed that my disc isn't held on to the hub at all, untill the wheel goes on and locks it. Is this normal, there looks to be a hole for a bolt to go through in the disc, but nothing on the hub itself? Many thanksPs , where would be best/cheapest to buy a set of track rod ends? I want to replace these anyway. Knocking could be a CV joint aswell mate. Normally there is a hole in the hub to put a bolt to hold your disc in place. My van ones arent in and its fine, makes a squeek sometimes. Nothing trivial Quote
cheezeitthedog Posted August 12, 2011 Posted August 12, 2011 Mine knocks like crazy atm when right turning and looked at cv joints. LHS boot split open and RHS boot gone completely and joint wide open :S Lowering tends to throw cv joints out repeatedly imoWas about to post link for where i got them on ebay but mines non ABS model :S If they do ABS version try uad-auto on ebay i got my 2 cv joints for £50 delivered to N.IPhil Quote
