epyank Posted August 12, 2011 Posted August 12, 2011 in my na it only has one hole for a engine loom to go inside the car but putting the glanza loom in there should b 2 sets of connectors going inside of the car...suggestions?drill another hole or are the non-ecu plugs not important?? Quote
whiteglanzav Posted August 12, 2011 Posted August 12, 2011 parts of the loom go through to the wings mate at each side there should already be holes there to feed the bits through Quote
epyank Posted August 12, 2011 Author Posted August 12, 2011 parts of the loom go through to the wings mate at each side there should already be holes there to feed the bits throughtortured glitch is here with his glanza right now nd he has 2 engine looms that go threw the engine bay?...dont kno what to do with at allu get my pm from a couple days ago? Quote
epyank Posted August 12, 2011 Author Posted August 12, 2011 theres 1 that goes directly behing the bulkhead then theres another one that goe directly behing the fuse box into the cab Quote
ryan lang Posted August 12, 2011 Posted August 12, 2011 theres should be an ovally shape rubber bung on the firewall just under the fuel filter, pull it out or cut a cross in it and just bosh the loom through there? Quote
epyank Posted August 12, 2011 Author Posted August 12, 2011 dont kno what the actual loom connects to think im guna just drill a hole threw the center of the engine bay any guesses or help what the connectos connect too?it is not the ecu loom!! Quote
Torturedglitch Posted August 12, 2011 Posted August 12, 2011 yes this is what we r on about but the hole isnt there on his gonna go back down tmrw with a hole cutter tyo put the hole in as it is just a blanking plate. Quote
epyank Posted August 12, 2011 Author Posted August 12, 2011 thaxs 4 u guyz help now who knos about fittin the glanza fuel pump into a na na only has 2 hoses wheras the glanza fuel pump has 3? Quote
epyank Posted August 13, 2011 Author Posted August 13, 2011 thinks thats a good idea..nd intending on doing that lol Quote
whiteglanzav Posted August 13, 2011 Posted August 13, 2011 thinks thats a good idea..nd intending on doing that lolI've got one sat here Quote
