Starbuck Posted August 17, 2011 Posted August 17, 2011 I'm having a thick moment. How do I adjust the damper so I can fit it back together, after taking it apart to fit.CheersOh and its a jezza one. Quote
Starbuck Posted August 17, 2011 Author Posted August 17, 2011 I'm having a thick moment. How do I adjust the damper so I can fit it back together, after taking it apart to fit.CheersOh and its a jezza one.Anyone? Quote
jezza Posted August 17, 2011 Posted August 17, 2011 The damper stiffness is increased by tightening the large blue nut toward the damper body. You can then adjust the rose joints at either/both ends to fit between brackets. Hope that makes sense. Quote
Starbuck Posted August 18, 2011 Author Posted August 18, 2011 The damper stiffness is increased by tightening the large blue nut toward the damper body. You can then adjust the rose joints at either/both ends to fit between brackets. Hope that makes sense.U mean the large gold nut? Quote
