Tommy_G Posted March 27, 2007 Share Posted March 27, 2007 as the title says, if you help my car shud be on the ground pretty soon.Tom Quote Link to post Share on other sites
paul w Posted March 27, 2007 Share Posted March 27, 2007 If the springs are on the front shocks then it's a piece of piss to do them! Jack it up,wheels off,undo the 2 bolts at the bottom,then the 4 at the top,remove old unit,and repeat for other side tthen its the opposite to put the new ones in! Half hr a side tops! Just make sure the bolts are sprayed with penetrating fluid the night before easy! The springs for the rear i'd get done at a garage personally,if the garage will fit the springs for you it's the same as the fronts for fitting the rears.Dont forget to support the car with axle stands so you dont end up with the car ontop of you! Quote Link to post Share on other sites
Glanza_Ragger Posted March 27, 2007 Share Posted March 27, 2007 buy a set of spring compressors from halfrauds.. chavmymotorworld etc... clam up the springs, take the topmount off and swap springs.. both front and back are the 2 hub mounting bolts.. and 3 front topmount nuts, 2 rear top mount nuts.dont forget when its done get your tracking reset.. Quote Link to post Share on other sites
Tommy_G Posted March 27, 2007 Author Share Posted March 27, 2007 cheers lads...may actually get it done for me as havent really got the time atm. Quote Link to post Share on other sites
Glanza_Ragger Posted March 28, 2007 Share Posted March 28, 2007 half hour a corner mate if your nippy Quote Link to post Share on other sites
ecksjay Posted April 2, 2007 Share Posted April 2, 2007 tracking sorted? bah, thats for pansies, leave it as it is, it'll drag you all over the road, great fun! Quote Link to post Share on other sites
