chrislucas121 Posted August 20, 2011 Posted August 20, 2011 Hi i am running on a wastegate and i need a gasket! Now if im right it sits out side that ring of metal ypu can remove, abd its 44mm 45 mm but cant find one and help has to be metal?? Ive tryed ebay but nothing only have 35mm and 50mm Quote
ToyotaTech15 Posted August 20, 2011 Posted August 20, 2011 Hi,Not sure exactly what part your on about, do you have links to the similar ones you have found?What turbo setup are you running?Gary Quote
