Astra MK5 1.7CDti 280mm 5 hole discs (has 4x100) (60mm centre bore)
Work needed: Mill them down to total diameter 277.5mm, you need to take 1.5mm off the thickness where it mates to the hub, and finally get a spigot reducer to fit the disc to the hub exactly
A bit long winded but these brakes are awesome, went crazy on track at Donington and they didn't fade once :)
A bit long winded but these brakes are awesome, went crazy on track at Donington and they didn't fade once :p
Cheers pal what make of disc are you using ? because i dont want to by any and find that there going to crack lol!! every set of standard disc ive used, have just cracked :)
will these be any good ??
http://www.ebay.co.uk/itm/OMP-280mm-FRONT-...=item4cf8173f71
http://go.microsoft.com/fwlink/?LinkId=121315
