Dimensions of connecting rods
Hi,
I will build for the 5E-FE engine has a variable valve timing.
But I need some calculations for the dimensions of the connecting rod. meant is not the total measured but run the two centers where the crankshaft and the piston pin.
Can anyone of you help?
Because of the 4E-FE, 4E-FTE near identical to me, this measure would be enough for now. the difference between the two connecting rods, I know him not only measured by holding one of the two.
