hill_bill10 Posted August 24, 2011 Posted August 24, 2011 Is it safe to remove them? does it make a difference to emissions? Quote
Asad Posted August 24, 2011 Posted August 24, 2011 nah, the activated charcoal is usually way past its best......rip it out and be done with it can also take the two "shiny" plastic pipes off and block the throttle body and blue valve on the engine Quote
Asad Posted August 24, 2011 Posted August 24, 2011 Loop some rubber tubing over it and put a tie clip on Quote
Steve GT Posted August 24, 2011 Posted August 24, 2011 dont block it upthe pipe coming out of it releases fuel vapour. just vesnt it straight to atmosphere i ran a small tube of vaccum hosing under the car and let it out that way. im guessing blocking it wont do it much good as the whole point of the charcoal filter when new was to release fuel vapour into the filter then the filter wil reduce the level of emissions coming out or something along them lines lol Quote
Stulet-GTT Posted August 25, 2011 Posted August 25, 2011 Hear ya go bud have a little read threw this...http://www.toyotagtturbo.com/forums/showth....Pic-s-inside... Quote
Asad Posted August 26, 2011 Posted August 26, 2011 by blocking up i ment the throttle body and small valve which is left behind when hes removed it all Quote
Steve GT Posted August 26, 2011 Posted August 26, 2011 Ahh I see sorry thought you meant the bit that comes out lol Quote
