looking to get some good bassy speakers to put in the starlet so that i dont have to have a sub
what i want to no is which ones are best?
where can i get them? put up a link
they are going to be running off of a amp for better sound as well
thanks in advance keiran
From personal experience I'd say that there isn't much that's going to replace a fully blown sub setup however I'd say that if you want a "halfway house" so to speak I'd go for a set of coaxial speakers and you could fire them in the back parcel shelf, if you're going to be using an amp you could get some 150 watt RMS units which would deliver a nice amount of punch & bass whilst still having the tweeters in the centre to clean up the sound a little, there are plenty of them on the market but I would say avoid some of the cheap ones online which cost about 30 quid for the set, a good pair of coaxial speakers should work well, especially if you combine them with a nice set of component speakers then you'll be cooking with gas.
Hope this helps.
-Doc
