engine temp went into red
it didnt even go into the red it was jut off it then i turned it off opened the bonnet and there was the overheated smell let it cool down and its been fine its an expensive job isnt it to change the head gasket?
Wouldnt worry about it then, only if in the red for a long period of time should you worry, the smell is just the coolant starting to boil. Might be worth changing the coolant as it will have lost its properties if overheated. And wouldnt know lol, I do all work myself.
D
