Whitegv Posted August 30, 2011 Share Posted August 30, 2011 Alright guys i changed the oil on the glanza this weekend. i normaIly use semi synth 5w 30. this time i used some.fully synth 5w40 and since this the car lobs bucket fulls of blue smoke out when i let off then accelerate again. could it just be the oil I've used or turbo seals or valve stem seals gone? Quote Link to post Share on other sites
LeeG Posted August 30, 2011 Share Posted August 30, 2011 did u over fill it with oil?? Quote Link to post Share on other sites
Whitegv Posted August 30, 2011 Author Share Posted August 30, 2011 Dip stick says not. worrying thing also is that the car seems to loose a fair bit of.oil. its not in the water and there's no leaks so the only place it can.be.going is out the back and out the breather? Quote Link to post Share on other sites
ktl Posted August 30, 2011 Share Posted August 30, 2011 do a compression test Quote Link to post Share on other sites
