Tobyb Posted September 2, 2011 Posted September 2, 2011 My neighbough is rebuilding a td04 turbo for me at his work, and he asked me whether the water lines and oil lines need to flow the opposite direction because of the turbo being used the other way up on a subaru, can any one tell me if you have to change the direction pin on them or should he just leave it be?Thanks in advanceToby Quote
rorenapier Posted September 6, 2011 Posted September 6, 2011 As long as the oil feed is on top as its gravity fedWater lines, pin closest to the motor, to the top, and obviously the other pin to the bottom. Quote
