epyank Posted September 3, 2011 Share Posted September 3, 2011 alright guys almost finished wiring up my 4efte conversion then ran into a road block, the n/a ignition barrel wont plug into the 4efte wiring loom so went and got a whole steering column from a ep91 except key wont work...so is it possible to swap my n/a ignition barrel over to my ep91 ignition that ive just bought?...how hard is it to put a new steering column in is there any way to get around doing it i.e shortcut?...n.e. helps apprciated thanksp.s need steps on how to swap barrels if possible too plz Quote Link to post Share on other sites
epyank Posted September 4, 2011 Author Share Posted September 4, 2011 ... Quote Link to post Share on other sites
Russleh Posted September 4, 2011 Share Posted September 4, 2011 yeh you can swap over the ignition barrel. i just done it on my n/a before i decided to break it. its a bitch tho because you have to try get into the 2 security bolts that hold it on and drill them out. I dunno how that will work for immobiliser etc tho but i cant remember if there is one built into the 4efte ecus anyway. Quote Link to post Share on other sites
epyank Posted September 4, 2011 Author Share Posted September 4, 2011 yeh you can swap over the ignition barrel. i just done it on my n/a before i decided to break it. its a bitch tho because you have to try get into the 2 security bolts that hold it on and drill them out. I dunno how that will work for immobiliser etc tho but i cant remember if there is one built into the 4efte ecus anyway.thanxs Quote Link to post Share on other sites
mech5107 Posted September 11, 2011 Share Posted September 11, 2011 You don't need to drill anything.You just turn the key between acc and on and there's a pin that you push and unlocks the barrel. Then you just slide it out. Quote Link to post Share on other sites
Russleh Posted September 11, 2011 Share Posted September 11, 2011 i thought he ment taking the whole barrel off the steering column :S Quote Link to post Share on other sites
epyank Posted September 12, 2011 Author Share Posted September 12, 2011 Gunna try that tomoz becuz totally gave up on gettin it on the road cuz of that problem, thanxs guyz Quote Link to post Share on other sites
Torturedglitch Posted September 12, 2011 Share Posted September 12, 2011 Dude I tried doing that but it was jammed so dunno whatto do what did the dude say? Quote Link to post Share on other sites
epyank Posted September 12, 2011 Author Share Posted September 12, 2011 need to tow it up to topgear performance on wensday...so gotta put bodywork back on make sure steering wheels alright nd brakes r ready to go for when i find someone to give me a tow Quote Link to post Share on other sites
