Max9650 Posted September 8, 2011 Posted September 8, 2011 So i thought i had an indicator out, so went got another one, plugged in and doesnt work, now ive found out it only works when you push the bulb in and it works fine, but if there is no pressure, i guess its not touching the live so not workingwhats the best thing to do? replace the connector? if so where is the best place? halfords? toyota? local motor parts shop?or any other ideas?Thanks Quote
nazzurro19 Posted September 8, 2011 Posted September 8, 2011 if it was me id bend the positive connection up a lil so that way it will make a connection , aslong as metal touches metal it will make a connection and work Quote
lugzy clart Posted September 8, 2011 Posted September 8, 2011 if it was me id bend the positive connection up a lil so that way it will make a connection , aslong as metal touches metal it will make a connection and work yer do this ^^^^ will work fine then fella Quote
Max9650 Posted September 8, 2011 Author Posted September 8, 2011 i will prob have a go on monday, cant be bothered to take that damn bumper off for like the 3rd time in the past few days lol thanks peeps Quote
lugzy clart Posted September 8, 2011 Posted September 8, 2011 u got a glanza or ep82???? cuz a 82 u dont need to remove the bumper to take to indicator off if its a glanza tho i aint got a clue lol Quote
Max9650 Posted September 8, 2011 Author Posted September 8, 2011 EP82, i have to open bonet, undo screw, then take 1 bolt off the bumper off so i can get a screwdriver under the indicator to pop it off,whats the simple way i should be doing lol Quote
Max9650 Posted September 8, 2011 Author Posted September 8, 2011 is that not abit dangerous lol !? Quote
