Stui White Posted September 8, 2011 Posted September 8, 2011 Hi,Is this meant to be unplugged?*SEE PIC LOWER DOWN*ThanksStu Quote
Josh@TunerLifestyle Posted September 8, 2011 Posted September 8, 2011 i guess so mate it has a blank off in it think mine has one off the top of my head! Quote
Stui White Posted September 8, 2011 Author Posted September 8, 2011 Thanks josh!Just adjusted my idle as it was droppin close to 500.Now at 800-900 sounds a lot sweeter idling :-) Quote
Max9650 Posted September 14, 2011 Posted September 14, 2011 Thanks josh!Just adjusted my idle as it was droppin close to 500.Now at 800-900 sounds a lot sweeter idling :-)What did you adjust? got same problem . Thanks Quote
Stui White Posted September 19, 2011 Author Posted September 19, 2011 Hi,What are these also? Found under my handbrake cover..... Quote
nazzurro19 Posted September 19, 2011 Posted September 19, 2011 is that not the sensor that tells you when your handbrake is on ? Quote
nazzurro19 Posted September 19, 2011 Posted September 19, 2011 What did you adjust? got same problem . Thanks on ya inlet manifold u have ya throttle body to the right of it , theres a small black blanking plate cover thingy bout the size of a 5p pull it out and underneath is a screw , adjust the screw to get the idle set up perfectly Quote
Stui White Posted September 19, 2011 Author Posted September 19, 2011 is that not the sensor that tells you when your handbrake is on ?Hi,There is a red/yellow cable off handbrake for this purpose.Im thinking perhaps one is for original rear speakers... Quote
Stui White Posted September 20, 2011 Author Posted September 20, 2011 Anyone else know what these 2 connectors in my latest pics are for?Thanks Quote
